TractorLinks.com
Show Parts for Model:
Re: Problems with Allis Chalmers Model B
steve(ill)
08-09-2013 15:14:57
hydraulic valve parts and orifices get plugged or stuck with dirty oil. Drain it out -- 3 of 1/2 inch pipe plugs on the bottom-- drain all 3. There will still be some residue inside so when you fill and run you will still see some "white" but much diluted. Leaks around the shift lever from setting outside are the most common problem. Use universal tractor fluid, hy trans, or 10 wt hydraulic fluid.. etc. Dont use anything over 20 wt thickness, it tends to cavitate the pump and make things work harder.
--On the starter, pull the starter and make sure the bendix spring is good and helping engage / disengage. Look into the starter hole and the ring gear and you will get an idea. Old is right, the motor always stops in the same spot.
