wc clutch adjustment
Anonymous-0
Hi all, is the clutch adjustment on my wc on the clutch shaft at the bell housing that has the bolt on it and is attached to the rod with the pedal . I don't see anything else to adjust. There doesn't seem to be much travel, unless it's wore out,also my gear shift swings around ( very dangerous )
Clutch adjustment is inside....swinging of the shift lever is normal. Nothing dangerous, just annoying.
black,
shoot me your email, I have a PDF of the service manual you can have, shows this and much more
Joe
