1948 WD hydralics
Del Kovar
New User
I have a 1948 WD Allis. Question, does the hydraulics share the same oil as the trans or is the hydraulics oil in the space where the belt pulley gear is located just behind the clutch housing? That space is vented into the clutch housing so that is what I am assuming. Looking for help. Also is there a seal between pulley housing and clutch housing? Thanks
You are right. The drive gear for the belt pulley is in the reservoir for the hydraulic fluid. The engine clutch shaft runs from the torque tube into the engine clutch housing. It has lobes to drive the hydraulic pump in the torque tube and a drive gear for the belt pulley in the engine clutch housing. There is an oil seal at each end of the shaft and a bearing in the middle.
The hydraulic fluid is separated from the PTO/transmission clutch/transmission/differential by the rear seal.
Front seal is to prevent hydraulic oil from leaking into bell housing. The seals all leak after some decades.
Thank you for the response. That is how I thought
it was. You wouldn"t happen to know the number or
size of that seal.
For the limited amount that I use my WD, I just top up the hydraulic fluid as needed rather than get that far into the clutch.
You can find the AGCO number by visiting this site:
http://www.agcopartsbooks.com/PartsBooksN/login.aspx?
As a Guest User, View Books. Pull down AGCO Allis and search by model WD. Go to Clutch - Engine Clutch Shaft. It is part #11.
Try your local AGCO dealer; or call SLI 888-252-0656
Del! why don"t you call Welters farm supply at Verona Mo, and talk to the lady that will answer the phone. She is very knowledgeable and probably will sell you the seals and whatever else you need. I recently put a new clutch in my WD45, and replaced the seals, while I had the motor out, I just took the old seals with me, and went to Bearings INC, and they matched them up for me, with CR seals. you might have a similar shop near you! Good luck guy!
