TractorLinks.com
Show Parts for Model:
Re: 1948 WD hydralics
stu (ON)
08-07-2013 09:29:54
You are right. The drive gear for the belt pulley is in the reservoir for the hydraulic fluid. The engine clutch shaft runs from the torque tube into the engine clutch housing. It has lobes to drive the hydraulic pump in the torque tube and a drive gear for the belt pulley in the engine clutch housing. There is an oil seal at each end of the shaft and a bearing in the middle.
The hydraulic fluid is separated from the PTO/transmission clutch/transmission/differential by the rear seal.
Front seal is to prevent hydraulic oil from leaking into bell housing. The seals all leak after some decades.
del kovar
08-07-2013 15:45:28
 Re: 1948 WD hydralics in reply to stu (ON), 08-07-2013 09:29:54
Thank you for the response. That is how I thought it was. You wouldn"t happen to know the number or size of that seal.
