Grease B axle pivots?
Anonymous-0
Allis B, tractor was a mess, wshbone had been welded such that the axle hoop is 1/4" forward of the support. Handy as there is a hydraulic cylinder mount sandwiched between them. SO, here's the question - do I grease the rear pivot and front bolt and support and bracket and hoop, or just run them dry?
No grease fittings there originally and the ones on Dad's 1948 B are still in good shape after 65 years. They'll probably be OK.
there are no zerks, but a abundant amount of grease at assembly surely would not hurt. I have taken a few apart that had 1/8 out of round holes due to wear. The axle dont move much, but any movement will cause some wear, given enough time.
