AC 200 power beyond?
Can you put a hydraulic power beyond line on a 200 AC? Just put a loader on it and have another valve to run loader and didnt want to tie up the remotes. Thanks in advance.
Not all that hard. I added one to my 190XT.
Place the power beyond valve in the line between the pump and the lift valve inlet (in series). You will also need a return line from the new valve.
I would just take the return line from your valve-body and run it to your loader valve-body then take its return to your original return line. Of course could go through the loader valve first then take its return line back to original valve high pressure side. Vic
