WC Sherman Trans Question
R Moline
On a Sherman transmission which way is which on the lever? Is forward/up regular or is rear/down regular? Thanks
Mine has 3 spots too, middle is neutral or disconnect. The tractor is faster in the lower/rear position but I don"t know if that is the regular speed or not.
The trans came as a under or a over only.from what I have seen the over drives has a dentent ball to lock it into place. The under drive one has 3 slots with a roll pin to lock it into place. Both are 30% up or down. Overs are good for the tractor ride people. The unders for the pulling tractor. Will not fit a wd. Value about $500
