Ron Muhlenkamp
I have a d 17 series 1.
Hydraulic pressure 2500 psi won't lift a 3 bottom Snap-coupler plow. With addition manual 50 lbs can lift plow, when release, it goes back down fairly rapidly. I replaced the pump with one that had worked. I believe that if the cylinder is leaking, it would pump hyd. Fluid into the differential pool. Would this be true when I'm not using the hyd. Or just when I'm using it
