Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: WD gears grinding when shifting
CTucker
07-24-2013 20:55:36
If you start the tractor with the foot clutch depressed and in gear, or if you are driving around and depress the foot clutch, you don't need to wait any time to shift into another gear as long as the tractor is STOPPED before pulling to neutral. If the gears start turning as soon as you hit neutral and grind trying to get it in a different gear, you either have a dragging clutch, bad throw-out bearing or a dragging pilot bearing
This post was edited by CTucker at 20:57:07 07/24/13.
Ptgallis
07-25-2013 13:09:36
 Re: WD gears grinding when shifting in reply to CTucker, 07-24-2013 20:55:36
That's the problem I have. From neutral, completely stopped it won't shift Into gear using the foot clutch or not. It only grinds.
Time to get a shop manual...do you have to split the tractor to get at any of the three possible suspects you mention?
Thanks
