WC----- D17 ?
I assume it will work for an unstiled WC, but I know the stiled WC flywheel bolts into the D17 crank, and then the d17 will bolt into WC just like the old wc motor. Only one way will allow all 4 bolts to line up.
Assuming you wish to put a D17 motor in a WC, I will say your life may be easier if you use the WC frount pully, and water pump-or at least we had to with the stationary power unit D17 block we put in a WC.
