190 clutch or transmission
J190
My 190 will go into gear when I first start it but when warmed up you need to shut it down to get it back in gear. When I do that with it in gear and the clutch pushed in it still wants to go like the clutch isn"t disengaging when pushed in. Is it adjustment, or a throw out bearing?
could also have a pressure spring come out and jamb the pressure plate so it does not release. Do you feel resistance on clutch pedal when you push it in? PTO probably does not stop either?
Sounds like the engine clutch needs adjusting and or replacing and you also have broken Powerdirector clutch discs inside the PD clutch ; common problem!
