Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Another Hyd. Hose Question
WI Dave
07-18-2013 20:31:27
I have a Freeman trip-bucket loader on my 1952 WD. If I replace the old 1/2" hoses to the loader lift cylinders with 3/8" hose, will the loader lift faster? Gain or lose power?
old
07-19-2013 07:02:14
 Re: Another Hyd. Hose Question in reply to WI Dave, 07-18-2013 20:31:27
Going small can/will cause more troubles and there is no reason to go smaller. Stick with the 1/2 inch hoses because the flow will be better and the heat will say lower etc.
greygoat
07-19-2013 05:43:40
Lift speed it determined by pump gallon per
minute rating at a specific RPM. putting smaller
inside diameter hose on..chokes the flow down,
makes the pump work harder trying to push flow
through a smaller opening, and results in heat buildup !
Bob Bancroft
07-19-2013 03:05:39
You won't notice the difference. Except that 3/8" hoses are plenty big enough both for that application, and to have to pay for!
willie in mn
07-19-2013 02:05:38
Pressure & thus lift force will stay the same. However, due to smaller diameter, oil flow/speed will be approx half. Willie
Leon R2013
07-18-2013 21:20:53
Mine came with 3/8 hose and I"m satisfied with it. Leon R
Retired Farmer
07-18-2013 21:03:00
You will have less flow thru the hose because of the smaller diameter.
LonnAC7050
07-19-2013 15:08:47
 Re: Another Hyd. Hose Question in reply to Retired Farmer, 07-18-2013 21:03:00
With the low flow high pressure system of the WD it will work just fine.
