Hydraulic Hoses for a Freeman Loader
WI Dave
I need to replace the hoses to the Freeman loader on my WD. Are the 4000lb max psi hoses at TSC strong enough, or do I need to find a higher PSI hose? The loader runs off the tractor"s hydraulic pump, BTW.
Those hoses should be just fine the working pressure on a WD is around 3200psi if I remember right but for sure is lower then 4000psi
