Desert Rancher
Howdy
I have a series 2(?) D17 gas tractor (ser.#32446) that I just acquired. Manual is on order, but I haven"t received it yet. Want to change out the fluids on the ol" gal so here are my questions:
--There is a dipstick with a breather cap on the right side of the torque tube. What does it check and what type/amount of fluid goes in there? Also, where is the drain plug for this compartment?
--There is a dipstick with a breather cap to the left of the gear shift lever. What does it check and what type/amount of fluid goes in there? Where would the drain plug for that compartment be?
--There is a dipstick WITHOUT a breather cap located under a cap screw on the UPPER LEFT of the transmission cover plate (left of the gearshift lever). What does it check and what type/amount of fluid goes in there? The drain plug would be where for that?
Final drives and engine oil, I have covered. Any help would be greatly appreciated.
Thanks
Desert Rancher
Thanks
Desert Rancher
