Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 6060 rear lift
Harry in Ky
07-04-2013 18:05:29
If the system hasn't been used much, it most likely has some sticky or just plain rusted moving parts in the lift valve. This is a common place for condensation to collect, especially if the fluid had water in it at some point and parts have not been moved much since. When you get the manual, read through the discription and operation portion of the lift system a few times to get familiar with how things are supposed to work. I suspect the issue is in the governor valve or the lift/lower valve. The governor valve is on the top of the valve body and can be removed easily for inspection. The other is on the bottom, so the valve body has to be removed and turned over to access it. It's not complicated, and with the book you should be in good shape
Nathaniel Watts
07-04-2013 18:11:10
 Re: 6060 rear lift in reply to Harry in Ky, 07-04-2013 18:05:29
Can you get to it with a cab? I am sure hoping I can get to see inside through the rear cover.
