AC 5040 Electrical Diagram needed
I haven't seen the diagram in years, so I can't give the color codes, but the system is fairly simple. Starter switch on the dash has two positions - one(left I think) for maifold heater, the other to crank. Signal goes to neutral switch on hi/lo shift rail then to a pushbutton switch under the tin cover on the pto shift lever and then to starter. Don't remember any relays involved.
the starter switch positions dash......
and, yes, that neutral switch can be a problem as I found out. It can be by-passed to see if it is at fault, but WARNING! you MUST HAVE THE TRANSMISSION in NEUTRAL to do any checking.
pic got left off
