wd air cleaner
Chris S NY
New User
I snapped the top tube (with the mushroom cap).To many tree branches. Before I weld it back together I figure I would clean it out real good. My question is does the tube in the tube come out or just the steal mesh in the inner tube. And who would have a gasket for the oil bowl. Or just use the same size o-ring.
I have a styled WC air cleaner complete except for the mushroom cap. Not sure if they are the same. I am 40 miles north of Syracuse and I could mail it to you if you are too far away. I was looking to get $10 for it.
Zach
(quoted from post at 08:45:05 07/01/13) I have a styled WC air cleaner complete except for the mushroom cap. Not sure if they are the same. I am 40 miles north of Syracuse and I could mail it to you if you are too far away. I was looking to get $10 for it.
Zach
Zach,
Do you have any WC styled fenders?
I didn"t realize it had a gasket either untill I power washed it and little bits of cork gasket came out. Thank you for the offer on the wc air cleaner but this is sill good once it is welded. I just don"t want to force the inside cylinder out if it is not so pose to come out. Then I will be forced to buy a newer one.
