TractorLinks.com
Show Parts for Model:
Re: Need some info on AC pull type combine
Will Herring
06-16-2013 15:49:15
Does it look something like this (albeit with nicer canvas)?
LA in WI
06-16-2013 20:12:37
 Re: Need some info on AC pull type combine in reply to Will Herring, 06-16-2013 15:49:15
The combine I looked at looks like your machine, but the grain tank is not as high as your"s and the discharge auger is in front of the tank. Does this make it a specific model?
LA in WI
Jerry Coulter
06-17-2013 05:27:27
 Re: Need some info on AC pull type combine in reply to LA in WI, 06-16-2013 20:12:37
The 60 All Crop had a 15 bushel bin, unloader ran on a disk clutch operated by a tightener wheel. The 60A combine had the 15 bushel bin, unloader had a shift lever which engaged a jaw drive, serial number began with A. The 66 combine series began with the same bin as the 60A, later stepped up to the 25 bushel Big Bin model. It had the longer discharge auger which was transported above the separator housing. The serial number began with B. Serial number is stamped into the metal below the left side separator door.
JMS/.MN
06-16-2013 23:02:45
Combine in the pic is a model 66, unloading auger stores above the combine housing. Model 60 is five foot cut and the unloading auger is attached to the front of the grain tank on a swivel.
LA in WI
06-17-2013 07:05:43
 Re: Need some info on AC pull type combine in reply to JMS/.MN, 06-16-2013 23:02:45
Thanks Jerry and JMS,
Thanks to you fellows the model is now determined.....now what is your estimate of value of this rig? High to low value is fine.
LA in WI
Tom Yaz
06-17-2013 12:33:09
 Re: Need some info on AC pull type combine in reply to LA in WI, 06-17-2013 07:05:43
In your neck of the woods, scrap to $500 or so
LA in WI
06-17-2013 13:46:39
 Re: Need some info on AC pull type combine in reply to Tom Yaz, 06-17-2013 12:33:09
Thank you, Tom.
That's what I need!
