G front wheel bearing seals
you have to work at getting them off, punch, screwdriver etc
you won't find the style of seal that's on it, but I've used both of these -
SKF seal is 11907
National seal is 473205
So, since the inner cup of the inner wheel bearing is pressed onto the spindle, I take it that the procedure is to pick apart/destroy the seal, in place, then use a pickle fork or the like to get behind the inner cup of the inner bearing, force it off the spindle then install the new seal. Then the inner bearing with inner cup could be pressed back on. Do I have the drill about right?
