altmodisch
I traded for a 1950 WD the man that I got it from said it was ready to go to the field. Well I Fixed a lot of problems on the tractor. I went to hook to the hay rake and went to make a turn and had a loud clunk sound in the rear wheel as I eased back to the barn the clunk noise happened 4 more times. I jacked the tractor up the wheel cocked in at the bottom and would clunk when turned. The axle would move in and out about a 1/4 + inches and wobble up and down. If you shoved in on the wheel and turned no clunk. What is wrong? How do I get the axle out? Is this going to cost a lot to fix? I have a lot of money in this tractor! Thanks!
