wood mower belt diagram
Go to woodsequipment.com and down load the manual.
you need to get the alignment correct and the belt routing or you"ll never get the belt to stay on. If you"r belt has been run twisted long it won"t hold the twist once the edges get wear it won"t grip correctly. If you follow the setup in the manual you should get long life from the belt. I mow 10 acres each week and usually get 3 years from a belt.once it starts twisting it time to replace.
