wd45 Carb problems
Lance Earl
New User
I have a wd45 with carburetor troubles. I ordered a rebuild kit for the wd45 and found out that none of the parts of gaskets fit. I got looking at the carb I have and it is a Marvel Schebler B11. I have been unable to find a carb kit for this carb or even find out what equipment it came with in the first place. I found on page that said maybe the Ford 8n. Does anyone have a clue?
I'll bet what you have is an MS TSX 871 which is the correct carb for a WD45 . Some times hard to read the numbers correctly. A 8 can look like a B and a 1 can look like a 7 or the other way around
Other than the Needle and Seat and the big Gasket, there is not much to replace...
The passage from the Main Power adjustment (in the Bottom) is where the sediment plugs them and is easy to clean..
Ron..
