allis d19 puller help
I have a d19 262 turbo diesel that I want to build up. bigger pump injectors turbo .....ex .if you can help me or know some one how can. thanks
when i built mine, i put a 7-3 leafspring in the pump and turned it all the way up. a garret T04 turbo, stock injectors, .020 over pistons, portmatched head and manifolds, 5 angle valve grind, and light smoothing on the intake runners around the valves added up to 130 pto hp. you will need to use ARP head studs and a copper head gasket because it will make over 30psi boost. it is an extremely competitive tractor. it's for sale, btw. rebuilding those 262's can get pricey fast.
I WOULD RECONSIDER A D19 DIESEL FOR A PULLER. IT WILL COST A LOT TO BUILD UP AND THAT MOTOR ISN'T GOING TO HOLD TOGETHER. TRY TO FIND SOMETHING WITHOUT THE ENERGY CELLS.
i got mine from a local john deere dealer that does injection pumps. is's a stanadyne piece. i wish i had the part number handy. but i would take dan's advice seriously. this project was not cheap and these motors cant take too much.
