info on a wc
souNdguy
I'm not an allis guy.. but do own a nice lil G.
was coming home fromt he inlaws and saw 'WC' parked in the weeds for sale.
noticed there is a lever at each ? bull gear? drop box by the fenders.
not fmilir with these models.. or most ac in general.
any info?
value ideas? etc
thanks
Levers sound like they could be hand brake levers, at a guess. Running and with good tires I would say up to $1000, not running and bad tires would be scrap price, in my opinion.
Zach
they wnted 1800.. said it ran good.
i oticed it had an alt on it with a cracked housing and not hooked up. :)
thanks for the info on price. I figured it was way overpriced.
ahh, neat.
does it have foot brakes as well?
it was up in the weeds and I couldn't get to see all the tractor.
can i assume styled / unstyled is the same as in JD terms? IE.. has nose sheet metal and fenders? etc.
if so.. yes. this had clamshell type fenders.. and some sort of nose grill..e tc.
The models with hand brakes have just that. I have a WC parts tractor and also the W Speed Patrol. Same engine as on the WD but with out hyds
2 pictures of a styled and unstyled W Speed patrol will make it so you see how the 2 are different Top styled bottom un
i say this had what looked like a flat plate on the right side of the engine. wd engine huh.. wow..
WC and WD engines are in fact the very same engine. Main difference is the fact one had hyds and the other did not and the WC had hand brakes and the WD had foot brakes.
Only reason I know much is I own to many tractors LOL. Have at least 4 that run and 2 or 3 others that are parts.
By the way the top picture is of my W Speed Patrol and the bottom one is one I knew of that sold and the guy sold it to cheap. He sold it for $1500.
Ya I use it to keep my mile long drive way in good shape. You almost have to have extra arms to work it but since I have had it over 15 years now have pretty much figured out how to use it with only 2 arms.
i work for a road contractor and have seen some pretty nasty contraptions that are old that used 2 handwheels on each side to set tilt and whatnot of blades via chain.
scarry stuff.. :)
Back in around the late 90s I drove dump truck in this area and did a lot of road type stuff and saw a lot of crazy things go on. Worked one job where there was no place to turn around so you had to drive a mile one way to dump the load then back up that same mile to get another load
ugh.
my late uncle used to be an over the road box truck and semi driver.
he said he used to deliver to this place in new yourk that you had to back into a 2 block causeway between 2 buildings to unload. and it was right off a 2 lane street. YIKES!
i'da been fired the first day!
I have out run people driving into my drive way. Me going back ward and then got forwards but yet I can go fast then they do. Then at one point do what is called a HP turn around and slide the front of a car or truck side ways to a point that your going forwards and take off. But then I did do some stunt driving when I was a lot younger
