Moisture in distributor cap
I taught a tractor restoration class for the first time and I would still consider myself s novice. We restored a wd45 and it ran like a top until spring hit and now it struggles to start. I noticed moisture in the distributor cap and it was a brand new cap. Any suggestions on how to keep moisture out.
Checked mine out . There in an internal cover that goes above the points and below the rotor and there is a gasket on the under side that mates with the distributor housing, may need replacement.
