Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: wd starter
handcrank
05-27-2013 15:29:04
It is a six volt system. The new cables are the heavy ones.I took the starter off,grounded it, hooked it up to a battery (six volt) and it worked.Could it be bad brushes? Hope this helps. Don.
teddy52food
05-27-2013 18:12:59
 Re: wd starter in reply to handcrank, 05-27-2013 15:29:04
Loose bushings are letting the armature drag under load..
handcrank
05-27-2013 18:28:22
 Re: wd starter in reply to teddy52food, 05-27-2013 18:12:59
Thanks for your responce.This is all new to me.I don,t know what you mean by loose bushings, Don.
old
05-28-2013 08:03:38
 Re: wd starter in reply to handcrank, 05-27-2013 18:28:22
Some old tricks that you can maybe try. #1 tap on the starter with a hammer. Do not whack it super hard just a few taps.
#2 pull the starter off and carefully rotate the back end cap 180 and then put the long bolts back in. What that does is puts the top side of the rear bushing down. The bushing wears the most at the bottom so if it is getting bad that some times will help it for a little while
Ralphwd45
05-27-2013 19:08:21
The armature spins in brass bushings on each end. These bushings are replaceable.
handcrank
05-30-2013 02:54:20
 Re: wd starter in reply to Ralphwd45, 05-27-2013 19:08:21
Thanks to everyone who offered to help.I tried all of the ideas with no luck.I removed the starter again,an hooked it up to a battery,and it worked fine.Maybe thats because theres no load on it?What would happen if I put it back on,an hooked it up to a 12 volt battery? Don.
cleddy
05-30-2013 10:49:30
 Re: wd starter in reply to handcrank, 05-30-2013 02:54:20
We been using our 2 WD's and now a WD45 with 12 volts for over 30 years and have never burned up a 6 volt starter. They turn over real good and as long as tractor starts okay it will work fine. I don't trust the locking the brake so turn tractor off more often than not to make sure it stays where it is suspose to. Try it and let us know if it works? If it still don't work than you need a different starter or a rebuild.cleddy
cleddy
05-30-2013 11:07:16
 Re: wd starter in reply to cleddy, 05-30-2013 10:49:30
Yeah we unhooked the generator and just used a fresh battery all the time. Coil & point-condenser take the 12 volts pretty good but 6 volt lights do not. You will be surprised how many starts a good battery has in it. It is Jerry-rigging at it's best.cleddy
handcrank
05-30-2013 18:39:04
 Re: wd starter in reply to cleddy, 05-30-2013 11:07:16
Thank,s cleddy and all others for helping me out.I put a 12volt battery in the old girl and it starts up an runs fine.I don,t have any lights so no worry there. I ,ll unhook the jenny and i,am ready to go.Many many thanks to all. Don.
handcrank
05-29-2013 19:03:25
