Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: wd hyd trans oiling one more time
mark wdnorton
05-26-2013 21:09:26
Willie- hand clutch is in hydraulic housing seperate from trans. Willie you say allis recommended 20wt or hyd fluid in hyd system and you say 80-90 gear lube in hand clutch ect hand clutch is in tube with hyd pump Stu says theres a seal between trans and tourqe tube when i took it apart there was no seal just a bearing im going to check stu s website for a seal this sure has me puzzled lets get this figured out mark
Brian G. NY
05-27-2013 06:08:19
 Re: wd hyd trans oiling one more time in reply to mark wdnorton, 05-26-2013 21:09:26
Willie is right; differential, transmission and hand clutch share the same oil. Hydraulic system has a separate reservoir.
I would guess someone put this together without a seal at some time in the past.
Stu"s picture and description should help; parts and repair manuals are wonderful things.
stu (ON)
05-27-2013 05:12:12
Best read this:
Enlarge page as best you can.
