mark wdnorton
New User
I broke pto off wd six years ago I got another torque housing to rebild. the bearing betwene the transmision and torque tube is not sealed. I have operators manual by jensales it says use 20w or 10w for hyd pump. On the same page it says trans diff trans clutch capacity 17 qts use sae80 all year. I do understand how foaming could cause problems in hydraulics The book also says fill all three compartments through transmission filler plug. My question is because bearing between trans and hyd is not sealed oil is going to mix between gear oil and hyd oil any thougts on this by you guys will be greatly appreiciatd mark here in ohio
