TractorLinks.com
Show Parts for Model:
WD45 flywheel / clutch
George Vincent
05-26-2013 06:40:21
Flywheel on my 1955 Wd45 has 9 spring pressure plate, motor needs rebuilding .Pulled another running motor for it , but this one has 6 spring pressure plate.IT manual reads "flywheels used on models wd and wd45 equipped with rockford clutch are not interchangable with same models equipped with auburn clutch" anyone run into this problem ? can i swap flywheel and clutch assembly? or will 6 sping assembly be ok in my tractor?
Jim seIl
05-28-2013 19:58:57
 Re: WD45 flywheel / clutch in reply to George Vincent, 05-26-2013 06:40:21
well I have used a wc flywheel in a wd, awd in a45 a 45 ina wc they are all the same I even put a wc flywheel on a e gleaner/ d-17 engine and put in a wc the 9 spring p/p is a must for a good running WD45 to mim slippage
Aaron SEIA
05-26-2013 17:57:41
From what I can tell of the parts book, the flywheel was the same. I think as long as you use the same pressure plate/clutch disc combination, you'd be ok. Never been inside a 45, but my WC and a couple of WD's I've been in have had the Rockford style setup.
AaronSEIA
BushogPapa
05-26-2013 17:00:37
WD tractors came with 6 spring Pressure plates...
The Spring Pressure Plate is a GOOD UP-Date for either the WD or the WD-45..
You could even put 3 more springs in a 6 Spring Pressure plate..if it is in good shape..
Ron..
george vincent
05-26-2013 17:46:56
 Re: WD45 flywheel / clutch in reply to BushogPapa, 05-26-2013 17:00:37
The 6 spring one was a wd45 motor that someone had put in a wd.Maybe they used the wd flywheel? would they be the same ?
BushogPapa
05-26-2013 17:57:30
 Re: WD45 flywheel / clutch in reply to george vincent, 05-26-2013 17:46:56
I think the clutches will inter-change between the WD and WD-45...
The 9 Spring would be the best choice...
Ron..
old
05-26-2013 10:05:50
Look at the flywheels closely?? Do the 2 look different?? As for swapping the flywheel yes you can do that since a WD45 crank shaft will be the same on any of them other then things like if it has be turned due to the engine being rebuilt etc
jd plowboy
05-26-2013 07:21:25
i havent heard of that but we had several flywheels from wds and wd45 and we didnt know which was which and we used the best looking one. i would use the 9 spring pressure plate cause you have more springs and more pressure on the clutch to keep it from slipping
Chris schafer
07-02-2013 16:46:02
 Re: WD45 flywheel / clutch in reply to jd plowboy, 05-26-2013 07:21:25
If any of you have a flywheel for sale from your wd 45 's please call Cory at 864-444-2896
