Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: WD45 Water Pump
Jack in Colo
05-07-2013 07:17:47
Had the same problem a couple years ago with my cousins WD45, if your radiator is full and you have no circulation then it's either the water pump gone bad or you have a stuck thermostat. remove the thermostat and check it to see if it is stuck, put the thermostat in a pan of water, put a thermometer (I use my wifes candy thermometer cause it clips to the pan) in the water and heat it slowly on the stove, watch the thermostat and see what temp. it begins to open at, should be around 180 degrees. if the thermostat is good then it's most likely the water pump assuming your radiator is clean and not plugged. I bought a water pump for my cousins WD45 from Yesterdays Tractors and it's still working.
