TractorLinks.com
Show Parts for Model:
Re: Allis CA 3pt
steve(ill)
05-03-2013 19:57:44
the present rock shaft holds your two upper arms. All you need to do is install two lift arms. They can be individualy mounted to each final drive, or put a steel beam betweent he final drives and mount the two arms to it.. Or look at a D10-12 setup.
OldMoIron
05-04-2013 06:32:09
 Re: Allis CA 3pt in reply to steve(ill), 05-03-2013 19:57:44
What would be the best size cutter, for a CA a 5ft or 6ft?
old
05-04-2013 09:12:49
 Re: Allis CA 3pt in reply to OldMoIron, 05-04-2013 06:32:09
I would go with a 5 footer on either one that way you are pretty sure not to power out. If your name here has any thing to do with the sate you live in as in MO and live in the southern areas I would for sure go 5 foot since we have some many hills to go up and down
Leroy
05-04-2013 08:51:21
What type of cutter? Finnish mower type or bush hog type. A 6' finnish will weigh less than a 5 ' bush hog and take less horsepower. So depending on what you want to do a 6' finnish might be easier to pull and lift than a 4' bush hog.
OldMoIron
05-04-2013 15:09:54
 Re: Allis CA 3pt in reply to Leroy, 05-04-2013 08:51:21
I have a SuperC also, I will be mowing fencerows and tree line, and the pasture got a few deer alleyways also. I sure didn't want to power out. Rebuilt the hand clutch on the CA so it should work out nicely
