Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Model M crawler engine
Mark Everett
04-25-2013 11:45:47
First off i would say radiator is blocked and or water pump not working.2nd the govener rod is stuck is the slide and will not move you have to free it the try again,Also if you have had the carb off make sure the little tab is located in the correct place on the cross shaft,or 1 last thing the linkage is binding.
04-25-2013 18:50:06
 Re: Model M crawler engine in reply to Mark Everett, 04-25-2013 11:45:47
When throttle lever is moved the governor linkage moves and the throttle shaft in the carb turns (took the triangular cover off end of throttle shaftand it moves) which indicates to me that there still might be a problem in the carb. Just had carb rebuilt but I guess there still could be a problem in it. It was doing the same thing before carb was rebuilt. As far as the overheating problem, even though radiator has a new core, there could have been junk in the block and head which have now blocked tubes in radiator. May end up taking top tank off radiator and checking for blockage. Thank you for the suggestions. Any other thoughts on the throttle issue?
04-26-2013 05:51:04
 Re: Model M crawler engine in reply to VCguy, 04-25-2013 18:50:06
Does it even have a water pump? Could it be a thermosyphon system?
M's are pretty far back tehre.
04-26-2013 08:20:36
 Re: Model M crawler engine in reply to dej(Jed), 04-26-2013 05:51:04
Yes, it has a water pump. Been rebuilt.
04-26-2013 10:32:49
 Re: Model M crawler engine in reply to VCguy, 04-26-2013 08:20:36
Does it have a thermostat? You don't mention that, so I thought I would ask. It could be sticking.
04-26-2013 15:04:34
 Re: Model M crawler engine in reply to dej(Jed), 04-26-2013 10:32:49
No thermostat
