AC 200 wheel pusher bolt specs
180doug
Would anyone have the specs on wheel pusher bolts on a 200 Allis, i think they have a different pitch thread than regular bolts? thanks
Have had no luck trying to find a set to buy. I borrowed a set from a neighbor with a 200 to pull the wheels off my 7000. His measured 3/4 course thread to screw into taper flange with area turned down smaller than the 5/8 wheel thread. Was going to make some out of grade 8 bolts, not sure if that is hard enough though. Mine were stuck really tight.
5/8 grade 8 normal thread. hope this helps
