Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: WC Questions
old
04-20-2013 08:21:24
With compression like that I would start by filing the cylinders with ATF. As for the wiring that is easy the big charge connection goes top the amp gauge the plug with the #2 goes to that stud and the #1 goes to the ignition side of the ignition switch or to the coil either will work. You will need a diode like the radio shack 276-1661 in the #1 wire line towards the alternator. As for the coil you can use a ballast resister like the O'Reilly's VR-1 instead of replacing the coil.
As for the carb the WC and WD use the same engine and same carbs etc
