Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: D17 Energy cell exhaust leak
Diydave
04-19-2013 04:58:46
I think it's just a copper washer under the button, as a gasket. Don't run it that way, you could start eroding metal, and that will require re-machining, at some point.
longrange9
05-25-2013 07:53:58
 Re: D17 Energy cell exhaust leak in reply to Diydave, 04-19-2013 04:58:46
I'm working on something similar, I think. I just replaced my head gasket and in the gasket set are some round copper ring washers that I bet are gaskets for the energy cells. Did you solve your popping sound by replacing these? If not, how? Thanks for the help. Gary
Jim 72
04-19-2013 08:22:06
Could you explain what you mean by the button? The leak seems to be coming from around an oval flat plate with two bolts in it. Is that plate easy to take off or will something come out when I remove the bolts? I was pulling a disk with it for about two hours and part of the way through it began to make the exhaust noise. I have only run the tractor that two hours since I bought it.
