TractorLinks.com
Show Parts for Model:
Re: serial number location
JoeM(GA)
04-17-2013 17:18:34
should be on the left front of the torque tube
max easterly
04-17-2013 17:31:01
 Re: serial number location in reply to JoeM(GA), 04-17-2013 17:18:34
Thank you so much for info. the tractor has been painted many times, so I will carefully remove. is the left side facing front of tractor or from drivers seat? thanks again
Diydave
04-18-2013 16:33:41
 Re: serial number location in reply to max easterly, 04-17-2013 17:31:01
Couple inches rearward of the carburetorwhere the motor meets the rest of the tractor. There is a flange on the motor, with the motor #, and an inch rearward on the tractor is the tractor #. Both numbers are on a sloping surface above where the flywheel resides.
max easterly
04-18-2013 17:01:00
 Re: serial number location in reply to Diydave, 04-18-2013 16:33:41
thanks for precise info Diydave. when rain lets up, I will get it.
David R Inman
04-17-2013 17:40:55
Tractors are always left side based on the seat.
Number should be stamped vertically down the front of the torque tube just behind where it bolts to the block.
max easterly
04-17-2013 17:49:01
 Re: serial number location in reply to David R Inman, 04-17-2013 17:40:55
Thanks again!! just getting started on restore project
