Farmall Super H M&W pump on Allis B?
Dick L gave me a good idea on adding live hydraulics to my B, I'm trying to figure out the following:
Will the M&W pump that bolted onto the distributor allowing the Super H live hydraulics bolt directly onto an Allis Chalmers B? Will any other Farmall model pump fit? Anyone know the specifications GPM, PSI or RPM? Is this a low pressure-high volume pump.
You may want to check if your B uses forged steel or cast iron timing gears. IH used cast timing gears on non hydraulic engines, they used forged steel timing gears on engines that had governor driven hydraulics though. A handful of gear teeth make a mess inside an engine. Joe
