TractorLinks.com
Show Parts for Model:
Re: wd timing
EricB
04-17-2013 10:04:03
30 degrees advanced is correct, that is at full throttle and the mechanical advance (inside the distributor)working. There is a timing mark on the flywheel but I have never found it yet on mine. The rotor turns clockwise so if you turn the dist. clockwise you retard the timing and counterclockwise for advancing it. If you have a tachometer for tuning......run the engine at idle...advance timing to where the rpm peaks...then back it off 50 rpm... if it runs to your satisfaction tighten the dist. at that setting. I've done it in older automotive application and had it come out at factory setting. One of these days I hope to find the marks on my WD flywheel...LOL.
