Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: D17 Fuel Shut-off and Sediment Bowl
Rodney Williams
04-16-2013 18:40:51
AH HA, a reducer. Thank you Old, that will sure speed-up getting this new-to-me, little thing running.
04-16-2013 19:12:49
 Re: D17 Fuel Shut-off and Sediment Bowl in reply to Rodney Williams, 04-16-2013 18:40:51
I open the inside hole in the threaded end of the fitting and insert an short length of 1/4" OD tubing 1.5" to 2" long. This raises the point of entry and prevents the junk from getting into the bowl. Some people also roll up a short piece of fly screen and insert into the hole in the tank fitting. This also acts as a screen
04-17-2013 01:57:36
 Re: D17 Fuel Shut-off and Sediment Bowl in reply to chalmersbob(pa), 04-16-2013 19:12:49
I did the same thing to the fuel cutoff valve on my Ferguson TO-35. The original cutoff had some type of screen built on it, but the cheap aftermarket units do not.
I just trimmed down a piece of copper tube and stuck it into the inlet on the cutoff, so it would pickup fuel higher in the tank,
so far, along with an inline fuel filter, inline from cutoff to carb, it has worked well for the last few years.
04-16-2013 19:10:23
You also might try this. Pour a quart of ATF in the tank and if it is off shake it some then drain. Let ti sit over night before you drain it. The ATF may help break the rust etc down and then help you drain it out
