Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: G-hot
JoeM(GA)
04-16-2013 15:16:44
no guage, no thermostat, don't run the water lower than top of the upper hose or you'll disrupt the cooling ability of the thermo-cycle style of cooling
Don't run it hot, most don't get a second chance
WAYNE-N-TX
04-16-2013 17:55:14
 Re: G-hot in reply to JoeM(GA), 04-16-2013 15:16:44
Joe, mine runs hot also, I can touch the water from the fill cap. Can you get to much fluid? I know you know a lot about G's.
JoeM(GA)
04-16-2013 18:28:11
 Re: G-hot in reply to WAYNE-N-TX, 04-16-2013 17:55:14
Wayne, if you feel down in the radiator and towards the back, you'll feel the top of the pipe the top hose connects to, I fill mine to there and have never had a problem with overheating. Might be time for a good flush and rinse. Also check for clogged fins, loose belt etc. With no water pump everything needs to be at it's best to work. I've never overfilled mine but would expect it to force the extra out as it expanded. Make sure cap is no more than a 7 lb one
WAYNE-N-TX
04-16-2013 19:36:54
 Re: G-hot in reply to JoeM(GA), 04-16-2013 18:28:11
Thanks, I know about the no water pump, I have a 1941 JD B, 1944 JD LA, neither has a pump.
Copyright © 1997-2015 Yesterday's Tractor Co.
