TractorLinks.com
Show Parts for Model:
Re: Setting WD hydraulics to
JMS/.MN
04-14-2013 19:14:52
You should have the operator manual, or at least the transfer (decal) that goes on the right side of the battery box. Shows all hyd settings. For Drawbar control (weight transfer) you screw A out of body. Screw B into body, separating plates. Screw D out as far as possible. (D is on the front center of the pump, NOT screw C, which is the screw on top of the valve assembly which contains the 3 hyd ports. Your and Bob"s assessment of how the system works is correct. I would NOT mess with the shims on the main spring- that is factory set and should need no adjustment unless it has been disassembled. KISS formula......simple adjustments first.
JMS/.MN
04-14-2013 19:20:07
 Re: Setting WD hydraulics to in reply to JMS/.MN, 04-14-2013 19:14:52
For HOLD position you want A into body, B out of body, locking plates together. D out as far as possible. Delayed lift is same as hold position, PLUS Screw C in, for delayed lift of rear cultivator gang.
