Trans/differential swap
wildgeese
New User
To swap out the trans/differential unit as a complete unit can I separate the trans from the torque tube by removing the four bolts at the front of the trans> Will it separate with those bolts pulled or will there be something holding the two together ( clips etc on the end of the torque shaft for instance so I'd have to get into the trans to remove those)?
Thanks
Jim
When you take those 4 bolts out, slide the tranny apart from the torque tube a little and there will be a cotter pin to remove from the drive shaft that runs up to the engine. Then it will come apart.
