Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 190 xt trouble
04-09-2013 04:28:39
You are probably going to need to rebuild your pump. Around here that would run about $500 at a good injector pump shop. Pull the fitting off the top of your pump to see if there is pieces of the seal ring clogging it up. You can bust the glass ball out to make it run for a while longer but not much longer. Usually though if that's the case the tractor will bog down after 30 seconds or less not after 30 minutes. Did you pull the sediment bowls off to see if they are clogged up? That would be my first move. Take a look in the tank too. My 190 had black electrical tape and feed sack strips of paper floating around and the fuel bowls would get clogged up. Had to drain the tank and take a shop vac with a 3/4" copper pipe taped to it to vacuum the tank out through the filler neck and sender unit hole.
