TractorLinks.com
Show Parts for Model:
Re: 1939 b won't start, low comp.
Paul from MI
04-07-2013 18:56:27
60 psi is a bit low, unless it has distillate pistons in it. Even so, it should start ok with that much compression. I would start looking at the mag and carburetor as the source of your problem. Hot spark and gas make a huge difference in starting. My old 2 cylinder Deeres start in very cold weather on about that same compression. As Old says, the low compression may very well be due to stuck rings, especially if the tractor hasn't been run much or worked enough to get up to temperature for a while. Maybe just a good workout will help a bit.
