c- allis update
roy prins
checked the rod bearings and found all were at less than 2 thousands -- shimmed out to 3 and a bit--now it turns like it should-- put the plugs back in - feels good-- needs new pan gasket and new oil -- then fire in the hole -thanks for all your help guys!!
Good deal! I would guess that the overhaul didn't include a fresh grind on the crankshaft. Most likely if you were to check 90 degrees from where you checked you would be close or slightly under the .002. You did good.
