Re: Allis C rear end
Zachary Hoyt
04-03-2013 09:43:42
I have a complete C rear end from transmission to final drives less PTO for $100 in northern NY. I do not know about the internal condition, the tractor was missing the wheels and had a stuck engine when I got it. You can drain the oil and look in by removing the cover with the shift forks on the right side of the tractor, that way you can check if the detent is not holding on 3rd or if the gear is worn and making it pop out. Zach
