Al L. in Wisc.
Good morning folks. I helped a friend of mine split his D 17, series IV, serial #88330; it was a first for me and a good learning experience. He has a manual for an older model and needs:
*the torque specs for the flywheel
*info on the hydraulic pump [book shows a rectangular unit and he has the round unit] as it leaks and he wonders if it has a seal and/or 'o' ring; easy fix?
He is very mechanically minded. The clutch plate was reduced to fibers and the flywheel is deeply scored with heat fractures; he purchased this tractor several years ago with full knowledge the clutch was very bad. The tractor doesn't get heavy use. Thanks in advance for your input. Enjoy your day folks.
