D-17 Gas Crank Pulley for Front Pump Hydraulics
KCTractors
Location
Central Wi
I have not seen the tractor yet, but I have to put a front hydraulic pump on a D-17 Gas. Is the crank pulley tapped for adding the pump shaft, also can I get the crank pulley off with-out much work?
Where can I get the items I need for doing this?
On a series III, the pulley is tapped for a front hyd pump drive shaft. Not sure about others, but should be visible from the the side. Google Heitman salvage in Wisconsin, specialize in AC.
On tractors prior to Serial #15931, the crankshaft pulley does not have the four tapped holes and it must be replaced with the newer pulley in order to bolt on the splined adaptor to accommodate the shaft that runs the front-mounted pump.
Another little tidbit: "Some tractors prior to serial #24001 will not permit installation of the 3/4" pump drive shaft because crank hole in front support is too small. Enlarge hole in support or replace support."
I have a Series II with Serial #34633 and I am looking to install a front mounted pump as well.
At least I won't have to deal with those first two obstacles!
I am in the process of accumulating the pieces I will need. So far, I have a pump that came off an Allis IB which was equipped with a side mounted sickle-bar mower driven by a hydraulic motor.
The pump appears to be large enough to run four rams for a fully hydraulic front-end loader.
At least, I hope it is.
I do not know if any of the parts are still available from Agco-Allis or not.
