G ready for grass cutting season
knot
New User
This is the second jd mower i have mounted on this tractor. Got about 20 years use from the first one.
Are you doing a double pulley driving a shaft, would love to get a close rear view, but it looks good from here!
(quoted from post at 20:50:06 03/15/13) Are you doing a double pulley driving a shaft, would love to get a close rear view, but it looks good from here!
Yes, i am running a double pulley off of the crankshaft. I will try to get some pics of the rear.
The JD tractor this originally went under probably had way more than the 10 hp of the G. So, how are you getting along?
(quoted from post at 09:12:26 03/23/13) The JD tractor this originally went under probably had way more than the 10 hp of the G. So, how are you getting along?
I think the man i got the mower from said the tractor was 18hp 3-cyl engine. It works good for lawn cutting. If grass gets too out of hand, I have a B with a 6' jd mower under it.
