wd 45 axle seal?
I'm talking about the shaft with the pinion gear on it that goes into the top of the final drive. It's inside the axle housing
70218450 is the inner seal, 70225844 is the outer. You can go to agcopartsbook.com, log in as a guest, and search WD to find the on-line parts book.
AaronSEIA
